Help with modifications
Panhead5496
Athens, Georgia
Hey guys, need some help making sure I get the right parts. I have a Baja warrior and ordered an air filter for it awhile go. http://www.shop.hotrodminibike.com/Air-Filter-Pleaded-25-Angled-KNF.htm
Didn't realize I needed more parts to make it work. :eek:
Is this all I will need?
http://www.shop.hotrodminibike.com/Billet-Air-Filter-Adapter-6931.htm
http://www.shop.hotrodminibike.com/Choke-Retainer-VK347.htm
The person at the company I emailed said I would also need this.
http://www.shop.hotrodminibike.com/Re-Jet-Kit-for-Stock-65hp-Predator-Carb-DJ-1245-1251.htm is that necessary?
I've never done anything to it except add a TC and straight pipe (which I'm going to have to order this http://www.shop.hotrodminibike.com/Bullet-Muffler-BM34.htm because the neighbors are getting a little upset at the noise lol)
Sorry if these were obvious questions, I just want to make sure I get all the stuff I need in one shipment
Thanks everyone!
Keystone Motorsports
But who was phone?
Lebanon, PA
The filter mounts to it. Once you remove the airbox there is no flange for the filter.
The jet is easy. You will need to modify a screwdriver to remove the old jet.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Staff Murderator
I hate it when a seller doesn't list the dimensions and/or the center-hole to center-hole spacing of something like an air filter adapter. :mad:
Shop around if you like. Tons of vendors offering the exact same thing around the interwebz.
Panhead5496
Athens, Georgia
I just watched a few videos and it doesn't look too hard :D I will be able to do it for sure! Thanks for the help
Yeah that is a pain. I think the reason is because he has them all listed under Baja warrior, but still would be nice to know for sure!
What are some places you recommend looking? I can't seem to find them anywhere.
Also, the "re jet" kit from there seems too expensive. What is the longer item that comes with the set?
---------- Post added at 08:02 PM ---------- Previous post was at 07:59 PM ----------
By the "longer thing" I mean the emulsion tube. Sorry didn't see what it was called
But who was phone?
Lebanon, PA
The emulsion tube is probably a larger diameter than stock.
I used an adjustable needle, can't find them anymore though.
If you want another e tube... Try going to a lawnmower or tool rental shop... They'll all have a junk drawer full of stuff... For those bits they might just give it to you...
I got a bunch of jets and a E tube for $5, cause that's all I had...
Panhead5496
Athens, Georgia
Thanks for the suggestions guys! I'm still not exactly sure where the emulsion tube goes and what it does.
@Mckutzy, I don't really want another tube (I don't know what it does) but the air filter upgrade apparently needs a different jet. Will any .035 jet work as long as it's for a 212 engine?
Panhead5496
Athens, Georgia
Ok that makes sense. So I would have to unscrew the jet and with some fiddling it will fall out? Then I can just slide the new e tube in?
Joe-405
Enjoying New Projects
U.S.A.
You have to have a larger idle jet also. Nobody has said anything about one yet. You will run lean and will be buying another engine without it.
