Help with gear ratios please
r97
Measure twice cut once
Massachusetts, USA
sorry i missed that....
i just checked, some crazy power here!
force pushing kart: 469 pounds
force required to spin tires: 225 pounds
and it also says you will reach ten miles per hour after moving 3ft, i think you would just loose traction but still!
if you changed to say a 4:1 ratio you would probably still spin the tires on dirt/gravel, and have a top speed (theoretical) of 39.48mph with the governor in place!
you can feel free to use this calculator like i did.
Cstyle00
Thanks, guys I feel better. My parts did come in yesterday, lol, driver and driven is huge compared to the smaller ones. Every inch taken up but there is room for it all. I should have it running by Sunday I hope.
Down to my last problem, small one but important. How do you hook up the throttle? I know how as far as run the cable threw the clamp but the little piece that holds the wire that pulls the throttle, how does it connect to the motor? It's the little piece with the screw on top.
Here is a link to the wire stops I bought, I bought the swivel stop and the round stops just to be sure. http://gokartsupply.com/thparts.htm
