Help, throttle cable connection to older briggs horizontal engine
PeterA
I have connected a twist throttle cable to what I thought was the throttle butterfly on the carby. But the engine does not want to run using that caonnection.
Removed the spring and wire that goes to the governor vane. Then connected my throttle cable to that part where the governor arm went to.
There is also another lever below the one I connected too.
The engine starts with the choke fully out, and there is no response when I twist the throttle, the engine just dies.
So I can start the engine and rev the engine if I hold onto the choke and use it like a throttle... which is strange.
Then I thought that other lever might be the throttle but it too has no effect on the engine.
I am thinking that the govenor spring and arm should have stayed on the carby???? Unfortuanatley I cut that control arm wire to remove it as I was thinking that I do not need the govenor.
What do I do now???
Why does the engine not rev like I want it too?
Does it need to be a combination of both the two levers connected?
PeterA
Here are some diagrams
first reconnect the governor!
that thing is in fact important to either be functional or completely removed.
bypassing the governor can and will hurt the engine eventually.
Be happy your engine dies atm.. just think the opposite would be true (it'd be running away)
w/o the governor it'll easily hit rpms that'll surely destroy the governor and as a result internal parts.. you'd have to completly check and maybe rebuild the engine :eek:
Now that this is out of the way..
WITH the governor installed and functional the throttle cable DOES NOT set the butterfly,
instead it preloads the governor which in turn sets the butterfly using the controlarm and spring you just removed.
You need a replacement kit (find it on ebay)
OR pop open the engine case and remove the governor completely.
No, this is not optional I'm afraid :( !
PeterA
I managed to sort things out and get the mini bike going. Took another carby off a similar engine. Put the governor spring and parts back on, and had just enough cable length to attach from the other direction.
The way it was hooked up would actually make the throttle plate close when you twisted the throttle.
Now there is not enough power, the motor will drive me, but I need more hp........
Again, since I believe you misunderstood my previous post:
You should NOT SET THE BUTTERFLY!
that will bypass the governor (attached or not)
and a bypassed governor means harming the engine eventually!
your throttle cable must be "cushioned" by the governor spring you reattached in order for the governor to be functional.
thus it has to go onto the plate, not the carb!
(once the governor is removed put it on the butterfly alright but NOT NOW)
