Help picking batteries
LSDOG
This is what I ended up doing. I used 18650 batteries to make a 20s6p with a BMS. Seems to be working fine but haven't finished the kart yet so no chance to properly test it yet.
Fully charge it and check how much time the motor can work and how fast if you can
Do you check every battery before installation, the nickel strips are good enough, they can deliver the amp without melting?
inchtime
UK
Thanks. I checked each battery and made sure the strips I was using could handle the high current. Looking forward to seeing how it all goes.
inchtime
UK
Thanks to those on this post that gave me advice on what to do with the batteries. I finished the e-kart and it worked well. Needs some tweaks on the kart but the Lion batteries were great. Here's a time-lapse video in case you're interested:
