I would not advise lead acid batteries, but you need to use SLA deep cycle if you do use them. You're talking about like 150lbs and several hundred dollars for batteries that can only be discharged 50% and have relatively few charge cycles. SLA is best for small toys that won't be used long like a 6v ride-on that comes with an SLA. Why not get some hobby batteries like
https://hobbyking.com/en_us/turnigy-heavy-duty-5000mah-7s-60c-lipo-pack-w-xt90.html?
SLA batteries are boat anchors, & like Epsilon Zero was pointing out,, SLA's are ''not'' really for ''repetitive'' ''high'' discharges.
That's why jump packs with SLA's , don't hold full charge capacity for very long,, & just get worse & worse. …
I think you would be throwing money away,, plus ''a lot'' of dead weight that you don't need.
Also running them in series with that 72v. set up,, you would drain/ruin them ''real'' quick.
Personally, I run Li packs that have BMS protection circuity integrated in them,, with using XT-90 anti spark connectors.
Like Functional Artist said,, a 48v set up is more practical & safer.
A 48v 2000w BM 1109 set up is what I run on my Kart, & does surprisingly well.
That set up with a 12 fet controller & Hall pedal, is only around $130 bucks.
You can get 13s - 4p - 48v packs with BMS for around 100 bucks ea. & run them parallel.
2 of those 48v packs, depending on ''actual'' capacity,, would probably give you your 30min. run time,, depending also on gearing, total gross weight with driver,, & throttle management.
I have been running misc. 36 & 48v Li packs with BMS, in various applications for over 3 years now,, & haven't had any troubles what so ever.
Maybe also look into hard case Lithium motorcycle batteries ??
They weigh ''tons'' less than SLA's & gels,, & are pretty safe.
My 2 cents.
I
