Russ2251
AZUSA:Powered by LAWN-BOY
I'd bet it's an ignition problem...nothing more.
I could be wrong as usual.
You may be getting an indication of spark, but:if it was ignition problem why would i be getting spark
either way i will check today
Sorry to butt in
You're getting close to the problem. Shock at the switch is a BIG hint.I also noticed I get a bit of a shock once in a while when turning key on the part where it says start
It sounds like you have some major electrical problems; at the very least, the whole system isn't grounded properly... &, yes, that would cause ignition problems...
