Help Kart literally running away lol
Racer2874
Just changed Carb. Now bike wants to take off like a bat out of **** when I start her. Adjusted idle speed. Is tightening the idle make it more sensitive? Or are there any other things that I need to be looking at?
Staff Murderator
Sounds like the higher idle speed is engaging the clutch, if ever so slightly. Is it a kart or a bike? :huh:
Racer2874
It's a kart. 212cc so should I tighten the idle or loosen it? If its engaging the clutch then it's really engaging lol cause it wants to go when started on choke but when i open it up to run just ever so slightly then it really wants to pin the throttle down and take off hard
---------- Post added at 09:56 AM ---------- Previous post was at 09:54 AM ----------
There is a lever that is attached to the other side of my carb that is super tight. It looks like it's attached to my govenor?? I'm wondering now if that's the issue
Lets see some pics...
Have you checked the throttle cable to make sure it's not pulling slightly.
I had this on a brand new engine, turned out throttle cable was pulling the throttle open a bit causing it to runaway.
Staff Murderator
You need a little slack in your throttle cable, it sounds like. It's not 'tightening the idle' as you say but it's all in the cable, tight or loose. Loosen it and report back.
Racer2874
Yes I checked gaskets and isolator are on correctly. I think its the throttle cable pulling the gate on the back of the carb open causing it too run off. I'll post pics son if I don't get it. Thank you all.
---------- Post added at 01:33 PM ---------- Previous post was at 01:22 PM ----------
It could actually be the return spring on the throttle. It's super tight just leaving the back butterfly valve on the carb wide open. Sound about right to anyone?
Poboy kartman
Senior Moments Member
White Settlement Texas
No....that would CLOSE it!
JollyKarter
Texas
Is it idling high or running wide open? I am wondering if you have something messed up with the governor/throttle linkage
Racer2874
Bummer. I believe it's gotta be the govenor throttle linkage.
---------- Post added at 04:59 PM ---------- Previous post was at 04:59 PM ----------
It's running wide open not idling high btw.
---------- Post added at 05:55 PM ---------- Previous post was at 04:59 PM ----------
It was the throttle linkage to the back butterfly valve. Had it slightly open. Thank you to everyone on here once again always a big help!
