What do you think two engines like this, is it any good?
I got another engine like this so I thought putting them both on a karting, dual engine. My English is bad, sorry.
So I did some thinking and I want to put two engines on karting, I thought to link them with a jackshaft so when I pull to start one engine second one starts also. On the other end of jackshaft I want to put centrifugal clutch and connect it to the axle. What do you guys think about that?
Sent from my Micromax A310 using Tapatalk
It's been discussed before, but the solution that was discussed then was a clutch on each engine and a live axle with 2 sprockets IIRC...
Bad idea...IMO....the engines will never be perfectly synchronized....so fight each other....and....think about how hard it is to pull start one engine...
Now you're going to do two at once?
I saw a youtube video as well and it seemed to work pretty good. They put it on the idler drum of a car dyno and verified that it accelerated twice as fast with both motors running. He had some issue with the throttle cabling, but once resolved it seemed to work well. Plus you could run it with either motor and the other just spun the outside of the centrifugal clutch without causing any problems. It was a live axle with no differential with side-by-side identical motors. I can't remember what they were exactly, just that they were identical.
These are the videos I watched. Looks like new Predator motors I think.
https://www.youtube.com/watch?v=-kN222TcGHk
https://www.youtube.com/watch?v=vDpjQnMg-nk
And you guys don't see the difference between what he described and what I described and how those YouTube videos were exactly engines with individual centrifugal clutches hooked up to a live axle? ???![]()
