dictionary6767
It came a off a tiller I have it on my tiller. It's a 3.75 horse power
Would i need a bigger sprocket or clutch or both, i like the size of the rear wheels.
it came a off a tiller i have it on my tiller. It's a 3.75 horse power
SMALLER clutch gear (more difficult)
OR
BIGGER axle gear (easy)
OR
smaller diameter tires (easy as well)
OR a combination of the above
It looks like you have a 54-60 tooth rear sprocket, try a 72 tooth sprocket, or larger if possible.
Remember, the acceleration will be better the more teeth you have on the axle, BUT, you will lose top speed and vice versa.
Also, is your carb opening up the whole way? If your motor isn't turning enough RPM's, the clutch will not engage properly.
It's outback under a tarp so I'll go check tommorow.
It looks like your missing the airfilter and cover, I'd reckon you should get one or make one
alot of these engines look the same. you can't be sure just by seeing it.
Oh i thought the 13 was for a model 13 B & S. So your positive its the 13 CID then?
