j.concepcion54321
Rebuilding KTM, Need Kart
Hey guys,
it was foolish i know but i just wanted to see if it ran after i cleaned the carb (didnt run before) and it did so i rode it around on the straight gas and then the engine would make a funny sound, get really hot, start smoking from the sparkplug area and turn off. then when i went to start it it would be harder to pull so id let it sit and then it would be fine. so id ride it again and the same thing happened.
I now realize that that was bad to the engine but what i want to know is what i can do to fix it? Should i drain the gas and put in some good mixed 2 stroke oil and gas and just let it run on that for a while? Do i have to take off the cylindeer head and pour some oil in there?? HELP!!!!
Thanks,
Josh
I now realize that that was bad to the engine but what i want to know is what i can do to fix it? Should i drain the gas and put in some good mixed 2 stroke oil and gas and just let it run on that for a while? Do i have to take off the cylindeer head and pour some oil in there?? HELP!!!!Thanks,
Josh
