help i have tried 3 different pull starts and still gets stuck it is a homelight212cc
Can you describe it better...
What sticks?... Does it not return properly? Hard to pull to begin with???
wildwood
kansas city
It does not return keeps getting stuck but i have just started it by a drill
I have used the drill becuase of it
anickode
S.E. Michigan
That doesn't answer anything.
Is it not retracting? Is it retracting part way and stopping?
Are you putting too much rope on? Most replacement pull cords are designed with push mowers in mind, so the cord is long enough to reach all the way up to the handle. If you wrap all the rope on the recoil mechanism it will bind up. You have to cut like 2-3 feet off.
wildwood
kansas city
it is not retracting like I put it on and then I puled it then it got stuck should the fan cover be loose or what would case it
