help fox locking up
jen hall
Lake county FL
Hey guys hoping someone can help me out as efficiently as before! I was advised to chage a rear bearing and that got my kids go kart up and running, the problem now is every few times its rode the axle seems to lock up after jt is shut down, the pull rope gets stuck at the point it usualyy cranks causing cart to want to lunge forward! Dont know if it has anything to do with the bearing i replaced but after manually pushing the cart backwards and forwards a few times it will "pop" then can be cranked! Please help if you have any ideas! The cart is a a fox with a factory 6.5hp subaru robin engine, with jackshaft.
colestreasures
Kentucky
Sounds like the chain is binding up , pics would be nice to look at, was it doing this before you changed the bearing ? If not then go back and check yourself/your work. JMO
Cole
KartFab
Dallas, TX
bad axle bearings wont help it go forward, its definitely something else (even if you have bad bearings, it doesnt cause it to lurch forward upon pull start.
could be:
1)bad/seized centrifugal clutch OR
2) bad/dirty torque converter (sounds like the drive unit if you have a torque converter)
3) chain, but that could also effect #1 if its too tight, but you said you have a jackshaft so thats probably just a torque converter cleaning issue.
4) high idle (unlikely)
jen hall
Lake county FL
Originally I thought it was the bearings as someone a couple of weeks ago on here advised me to jack it up and check for movement of the rear axle back and forth! I did that and you could move it quite a bit, so I checked the bearings and the right one was shot (completely fell apart as I removed it although the inner ring had melted to the axle slightly and created a groove that it wouldn't move past so I sand the axle down with emory cloth where it had built up) replaced both bearings. It was getting caught up every 3-4 hard turns then would pop after pushing it forward, and start right back up. Now it's unpredictable seems like after it gets good and warmed up about half an hour into the kids riding it. Howwould I go about either cleaning the torque converter or determining if it's bad? The chain appears to be ok, I watched it as I pushed it forward looks good and well oiled! I don't know if this is significant but when pushing it forward to get it to "unlock" at times you cant pull it backwards at al as the wheels will completely lock up, front in lifts, completely seizes!! I will try to attach pics that I sent the last time.
jen hall
Lake county FL
Unable to post pics at this time **** technology my kids helped me post them last time too late for the kiddos will try tomorrow. They are on here somewhere with the question I had a couple of weeks ago can't find that post either! Thanks for your time!
