jen hall
Hey guys hoping someone can help me out as efficiently as before! I was advised to chage a rear bearing and that got my kids go kart up and running, the problem now is every few times its rode the axle seems to lock up after jt is shut down, the pull rope gets stuck at the point it usualyy cranks causing cart to want to lunge forward! Dont know if it has anything to do with the bearing i replaced but after manually pushing the cart backwards and forwards a few times it will "pop" then can be cranked! Please help if you have any ideas! The cart is a a fox with a factory 6.5hp subaru robin engine, with jackshaft.
