help engine won't start
Nick
Hoschton, Ga
Easiest way to clean a carb (or do just about anything) is to google it or look for a video on youtube.
I suggest keeping notes on how you got it apart like toystory said and then use a can of carb cleaner along with a toothbrush, q tips, paper towels, and some thin wire to run through the really tight places. After you get it clean and put together I would spray a little bit of the carb cleaner into the air intake on the carb and let it idle for a while just to make sure you got it all also doing this every once in a while should keep it running smooth.
