help engine won't start
drew15
Hello, I am looking for some help. I can't get the engine running on my go kart and I am clueless as to what the problem is. It is a 5 hp robin/suburu engine, I just replaced the clutch about 2 weeks ago and about a week ago I took it out for about 45 min and it ran like a champ, when I pulled it back up to my garage it bogged out and stalled and now it won't start back up again, I don't get it. I did oil change about 2 weeks ago, I just replaced the spark plug last night hoping that was the problem and apparently it wasn't cause it still won't start. I don't know much about engines so I was hoping to get some ideas on what the problem might be??
I can't check compression if it won't start up, can I?
Yes you can. Compression is usually tested with the engine off. Take the spark plug out, put your finger in the hole and then pull the starter. If your finger is forcefully pushed out the hole by compressed air, then you have enough compression. To test it accurately, you can get a compression tester, screw it in and pull the starter.
Yep, what he said...
Before you pull the spark plug out, set the engine as if you're trying to start it (fuel on, choke on full) & pulll the rope a few times. When you remove the plug, it should be wet; that'll tell you/us if it's getting fuel...
drew15
I'm gonna check the compression tonight I will let u guys know. I don't know where the low oil sensor is, there shouldn't be any oil problems I just changed it 2 weeks ago and have no leaks. I appreciate the help and ideas u guys are giving
souperman000
Westlake Village, CA
The problem with the new industrial engines' low oil sensors in a karting application is that a lot of times on a sharp turn the engine will shut off. This is because the oil shifts and the sensor reads it as a low oil level. The sensor is designed for a stationary engine Just one simple thing to check before ripping apart an engine.
CaptCanadia
Acton, CA USA
In my personal experience the thing that goes wrong 99% of the time is fuel. If your compression check comes out good check the carb. Just take off the carb bowl and spray some carb cleaner through it. If you live in a dusty area like I do and you don't keep on top of your air cleaner this is easy to happen.
drew15
Ok so I'm getting good compression, fuel is getting to spark plug. Today I noticed when I pulled the cord a couple times it starts for a BRIEF second then immeditely boggs out and also noticed tonight after a few pulls a couplesmall puffs of smoke that smell like gas
CaptCanadia
Acton, CA USA
That sounds like flooding. It could just be from you trying to start it so much. Try checking the timing to make sure it is correct. The only other thing I could think of is maybe your carb float is stuck or the carb is just dirty?
Before going any further, check oil level (to be safe) and unplug low oil sensor. Attempt to start, report results.
If spark plug is rather wet, I may be flooded. To remedy, remove spark plug, and blow dry. Shut fuel valve off, place a rag over the spark plug hole, and pull starter briskly several times. Reinstall plug.
drew15
Oil level is fine just checked it to make sure, where would I find the low oil sensor plug? Sorry I'm not very good with engines, but I guess I'm getting a little expierence now lol
Post some pics of all 4 sides of the engine- nice closeups- we'll find it... If it's anything like the Hondas, the oil sensor wire exits the engine block on the front side (towards front of kart) about halfway up the crankcase.
drew15
Ok found the oil sensor and come to find out it has been disconnected since I bought it which was about a month ago, I re-connected it and same result, it won't start up. I was messing around with it some more and found out if I hold the throttle back and pull the cord it starts up and I can keep it running by messing with the throttle, as soon as I let go of the throttle it immeditely boggs out and dies
drew15
When I clean the carb, do I need to take the whole assembly off? Also is there a fuel line or something I need to disconnect first?
Yes, and yes.
You will have to disconnect all hoses and linkages from the carb, and then unbolt and remove the carb. Take detailed pictures and notes as to how it goes back together. THIS IS A MUST! Then, read up on carb cleaning.
