Grumpygregg
I need help on this clutch. It is on a Carter trail buster. I bought it yesterday. The driver is different from all pictures I have seen. First is it has 2 brass rollers under the belt on the fixed face post are they the same as the bushings as in the moveable face? Second question is the spring is missing and there is only one brass bushing in the moveable face should there be 2 brass bushings in there? I know it needs a spring and I will order it and all bushings at the same time just need to know if I need 4 bushings or 2. Third question this 40 has a 3/4 inch adapter for the motor shaft are they just pressed in and can they be removed? The wife wants to up grade the motor from 6.5 clone to 9hp or more so it can have electric start in the future.
Tim
Tim
