This is my first time messing with anything mechanic mak, I bought the go kart off of someone and I am trying to get it running. The only thing I have left is to put the last chain on. I have already sized the chain and test fitted it but it’s crooked because the sprockets and align perfectly causing the clutch to made a rubbing noise and spark a little bit. The clutch is fine with the chain isn’t pulling on it. I don’t have anymore axel to work with so I’m not sure if I’m supposed to Move the whole clutch over or what.
Here are some pictures
Thank you !!!
Thank you !!!
