Hello all!
Need some help here please..
The Details:
Have a Baja DN 150 frame that I've recently ripped the GY6 engine out of and swapped in a Predator 420cc engine. I have a 30 Series torque converter (TAVI 2 type), a forward/reverse gear box, and a home-made jack shaft.
I retained the original axle sprocket (31 tooth) and fabricated a drive sprocket out of the original drive sprocket off of the GY6 (16 tooth).
From the Predator to the 30 series torque convertor, with a 10 tooth driven gear, I have a chain connecting to the forward/reverse gearbox. the input of the forward/reverse gearbox is also a 10 tooth gear, so a 1:1 gear ratio so far.
The gearbox is a 1:1 forward drive, and a 1.2:1 reverse drive to the output shaft (which I have fabricated into a jack shaft).
On this jack shaft I've mounted the original 16 tooth drive gear from the GY6 and this connects to the axle sprocket (the 31 tooth)via the original Baja DN 150 double chain (I think it is a 57 link double chain).
So final drive (forward) should be 1.93:1 (31/16 right?)
The Issue:
When on jack stands everything turns perfectly. No binding, no grinding, no issues. I can shift from drive to neutral to reverse with no issues and the drive axle spins smoothly.
When on the ground however, I have to full throttle it just to get it to move a couple of inches. The belt on the torque converter slips so bad, and melts against the drive side of the torque converter.
I think that the drive ratio is off, but before I go ahead and commit to that rework, I'd like to know if there is anything I can do to the torque converter side first?
I have attached pics to help with diagnosis.
The Details:
The Issue:
