Hello from Arkansas
jjarkys
Springdale AR
Greetings from NW Arkansas. Been doing a lot of research on the site lately. Great resource. Almost done with my first kart project. Two seat dune buggy style for my 6y old. 6.5 HF Clone with some external mods. First time I've done any mods to a clone and I'm working through some issues. Any advice is appreciated. Here's some pics.
Wait, what? That's for a 6yo?
I merged your two threads as we don't allow double posts but, I understand why you did...
Welcome to the forum
jjarkys
Springdale AR
Thxs. Sorry about that. I use Tapatalk and sometimes it doesn't want to cooperate. I wasn't sure it posted the first time.
He'll be seven in a couple of weeks. He's a big dude. He barely fits in that quarter midget seat.
Even though I used 1 inch .065, I'm concerned about the 6.5 pulling it up hills. We'll see.
Well, at least you used a torque converter, that's a good start... :thumbsup:
Wait, I just noticed, the rear frame is articulated but, there's no suspension; what's that about?
WELCOME!
That's a beautiful buggy you made there,
and it looks like there's even enough room for an adult, so that looks like some decades of fun.
Great work!
One thing though: It's surely heavier as a standard kart, and for a 6yo that's perfectly fine with a 6.5HP engine, but I guess you should already plan in to mount a bigger engine in... let's say 8-10 years ;)
jjarkys
Springdale AR
WELCOME!
Agree. The 11 or 13hp will probably be in there at some point.
Gotcha :thumbsup:
Do you honestly think it'll take that long? :lolgoku:
No it'll take two-three, but I think you can reason to "not get a bigger engine" with at least a twelve year old ;)
[Or you did something wrong]
With puberty though.... get the engine, you can not argue with hormones :D
That is an awesome buggy!! How have you kept it so shiny? My stuff starts rusting within a week.
I would also agree that a bigger engine will be needed soon. You will then have to get the 40 series TC or equivalent
jjarkys
Springdale AR
Not sure on the rust. I don't do anything special other than start with clean tube. Climate maybe?
I bought this engine a couple years ago so figured I'd start with it. If it's not enough ill move it to a smaller kart for my youngest and go bigger. Just got to bleed the brakes and it will be ready for first test drive.
Thxs
Yes. Will that be a problem?
Not necessarily. Usually with buggies you don't use a #35, but seeing that your engine is only a 6.5HP, you should be OK for the moment.
If you get anything larger than a 6.5HP, I would strongly suggest that you go up to a #40 chain. You will have to change out all your sprockets as well. #35 chain is just not made to withstand high torque and could snap
jjarkys
Springdale AR
Thanks for the heads up. I got the 35, because the TAV had a 35 sprocket on it. If I change engines, I'll have to switch TAV because of the shaft size. That will be a good time to switch chains.
