Heavy axle!!
JMack1995
Melbourne, Vic, Australia
hey guys, i have come across a possible problem :S
i have bought 35mm bearings, sprocket hub and disc hub for my cart and finaly got the axle today. the axle weighs around 8-10kg meaning the back of my kart is pretty dam heavy!! with such a heavy rear end would it possibly burn up my max torque clutch and would the hydraulic breaks wear down fast? would one break be enough to stop this weight?
r_chez_08
Should be in the shop...
Cornwall, UK
The axle will be fine for the hydraulics, i have hydraulics and a 30mm axle, no problems ever.
Burning up of the clutch depends more on gearing. What sprockets do you have, how big are your tyres and what engine do you have?
sideways
Unfinished projects king.
Perth, Western Australia
It'l be fine, if you're really concerned then go up a few teeth on the axle sprocket.
The weight of your wheels and tyres will make more of a difference than the weight of your axle ever will.
8-10kg isn't really that heavy.
JMack1995
i have a 219 pitch max torque clutch with 16 teeth and a 219 pitch 66 tooth sprocket. i know this isnt the best of ratios so i might get a 90 tooth for the back or something later on. and i have an old suffolk super colt which i am hoping to trade in or just buy a bigger engine.
r_chez_08
Cornwall, UK
What size tyres and what motor? The ratio doesnt sound great. Where you located? I have a 93t 219 sprocket which i ran with a 16t maxtorque style clutch on my kart. It is used but you can have it for shipping cost.
No doubt. But meantime, don't go any bigger with the tires- this will help make the best use of your current engine. Big tires take more power to turn, even with an equivalent gear ratio.
r_chez_08
Cornwall, UK
That eqates to 18mph if your motor revs 3600rpm max.
May be ok. I am interested to see what this 1.1hp motor is, and how you mounted the clutch.
Only problem is that you will get very little ground clearance.
Toystory: smaller is not better in this case, the sprocket is 9" diameter!
You may be better off getting a stronger engine and bigger tyres.
JMack1995
So is it 18mph with the 66 tooth or the 93 tooth sprocket? And I remeasured and the wheels are about 13 inches so there will be enough ground clearance for sure. The engine is an old Suffolk supper colt lawnmower engine and is about 40 yrs old. My pa it out of his garage put some fuel in, primed it up and it pull started first shot!! Bloody unbelievable seeing as he hadn't started it for about 20 years.
