Heavy axle!!
r_chez_08
Should be in the shop...
Cornwall, UK
Yeah tomorrow if I get round to it. It is usable, but since I only paid £6 for it, i cannot sell it.
It is aluminium. A couple of the teeth are slightly damaged where the chain came off.
Reason i dont need it anymore is because I have changed to #40 chain and sprockets which suits my kart much better.
r_chez_08
Cornwall, UK
Because it is stronger, less likely to come off, i can find jackshaft sprockets for my torque converter, and the sprockets are thick steel and do not wear or bend as easily. My kart is thrashed off road through fields though and I have a 6.5hp clone. #219 will be fine for you, just keep the chain lubed.
redsox985
PA
Also, with a sprocket so large relative to your wheels, make sure it's near a tire to help prevent it from bottoming out and messing up your chain.
r_chez_08
Cornwall, UK
Here are the pics of the stuff.
I have 1x 93t sprocket, OK condition, a couple of teeth damaged like the picture.
3x cables. 1 approx 2ft, no end, 1x approx 4ft, no end, 1x approx 6ft, gear type end.
1x chain, approx 3ft, pretty good condition, however it requires a master link, chain splitter or a hammer and a punch to join it.
Please see your PM inbox
JMack1995
Melbourne, Vic, Australia
Ok cool I'll definitely take the sprocket and the cable, do you have the outer casing for the cable? I will be using my cart on mainly road, gravel and a bit of grass, so nothing to strenuous.
r_chez_08
Cornwall, UK
I can have a quick look tomorrow, but it is unlikely. I had a whole bunch, as I replaced 3 cables on my bike and removed the old one from my kart, but it all went in the bin, as it was a little stiff. Can you not get it cheap in a bike shop near you?
You will have about 1.5" ground clearance which will probably be enough.
