Head still leaking
a3ill
I have put a new head and gasket on my kart. Tightened the stud nuts down to 16 ft lbs in a criss cross pattern. Then to 25 ft lbs the same way and the head gasket is still leaking. I don't know what else to do. is there some other sealer i should try? thanks for any help.
a3ill
it looked okay, but i havent done much motor work so i probably wouldnt know what is bad or good.
:lolgoku: obvious answer is obvious.
Is it leaking from the head-gasket or from another spot (valve cover or something)
If so replace the gasket in question and try again -aka report back.
Russ2251
AZUSA:Powered by LAWN-BOY
If head is off engine, or if you remove it again, post some good clear high resolution pics of both surfaces...meaning head surface and block surface.
This may tell us something.
Keep in mind that sometimes gaskets will normally 'weep' some oil.
