firemanjim
Just kartin' around....
Ok, well I was asked about the hf bender I use, and if I had any tips on use. Well, not really..... I get lucky and lot, I guess.
I was asked about something specific, so from here on, that's what I'm talking about....
Ok, was asked about a bumper made from 1/2" gas pipe (black pipe sold at homedepot / lowes..... And chancer wants it 6x18x6..... Hmmmm
Well, like I said , I have a scrap piece I use for measuring and layout.... I hope these pics help you....
The center of the die needs to be marked. PERMANENTLY..... Now, from there to each end, is right at 2.940" so you're looking at 6" of bent tube, right there.... I think the other pics are self explanatory. The length from outside to outside, at the ends of the bend. Wait, from the outside edge, the bend stops at 4.375". So, knowing that, you need 9.25" between the bends.... To get 18" width. (could be off a tad. Remember, I get lucky and lot...
So, if I'm right, you need to measure from one end 4.565". Bend at a 90. Should end up 6" from end of tube, to outside of pipe,after the bend. Again, could be off a hair.... Now, from the end of that bend, make a mark at 12.180". That's the center of the next bend. Should end up 18" wide, with a 6" depth/length.... Should be a 23.5" piece to start with..... Do the math though. It's been a bit since I've played with the bender.....
Use my figures as a base line..... Look at the pics too. Should make sense.
Im trying to do this with as easy as to understand verbage as possible. Trying to explain center lines of radii and stuff just ain't no fun. My best advice, is to get some scrap, marketing the center, and see what you get when you bend certain angles. Mark the center, beginning and end of each bend, for future reference.
)So, if I'm right, you need to measure from one end 4.565". Bend at a 90. Should end up 6" from end of tube, to outside of pipe,after the bend. Again, could be off a hair.... Now, from the end of that bend, make a mark at 12.180". That's the center of the next bend. Should end up 18" wide, with a 6" depth/length.... Should be a 23.5" piece to start with..... Do the math though. It's been a bit since I've played with the bender.....
