mbennett66
- Messages
- 21
- Reaction score
- 0
Hello all
New here. Just picked up a go kart off CL. Has a newly installed engine from HF (the 96549). Seems from the forum that this is a great engine for the price.
Starts nicely, and seems to run good, but very rattley (if thats a word). I cant tell if its the clutch or just general rattle of the whole kart.
I thought about putting short clip on youtube for someone to listen to and tell me their opinion.
Does anyone have an advise or opinions.
Another question, I picked up some hard rubber grommets in the Northern tool kart section. I assume these can be used like motor mounts between the engine and frame. Is this ok? I thought it might help with some of the vibration.
Finally, my setup is as follows. I was wondering what I should expect for performance. Speed vs. power. Not really concerned about speed since its for my 5yr old son, just curious.
V-Belt centrifugal clutch on the engine. 3 inch v belt pulley.
This drives the jackshaft which currently has a 6 inch pulley on that side.
The other end of the jackshaft is a 12 tooth sprocket turning a 54 tooth sprocket on the tire side via chain.
How tight should the belt drive portion and chain portion be. How much play?
thanks
Micah
Murfreesboro Tn
thanks
Micah
Murfreesboro Tn
