Gy6 150
chaz
So I got a new wireing harness for my gy6 and am having trouble I have no spark need help please!!
Might have something to do with an engine kill switch, or wiring, that is grounding out the spark (creating a no spark condition).
But that's my wild, shot-in-the-dark guess with so little information 😬
h3re4fball
Johnstown, Ohio
You need to grab your multimeter and start testing. There is an EXCELLENT video that will walk you through this step-by-step. Follow this, and you will find your issues.
Sincerely,
-A Guy who has chased down a lot of GY6 issues.
Karttekk
Elizabeth, PA
Sincerely,
This is a great tutorial. In addition to a multi-meter, I would suggest picking up a 12V test light. You can work your way through the connections and harnesses with a test light to see where you're losing your hots or grounds. I've repaired a bunch of these machines this way.
chaz
And also the new harness did not come with a diagram so I'm lost there as well
Sandmanbjj
I personally feel the only fix for the GY6 electrical system is a can of gas and match. I don't have the patience. that's not helpful I know and apologize.
chaz
What do you mean "rest"? The electric choke on those are pretty simple plug-and-play's that do not need a lot of tuning. Are you trying to adjust that?
I meant "test" lol stupid auto correct!! But I figured it out
chaz
Ok guys ran into a problem now when I try to stsrtthe gokart it just clicks!!!
chaz
Try jumping the solenoid - screw driver across both screws. Report back with the findings.
Also, make sure your battery has charge
Same thing just clicks battery has a full charge. I even changed the batteries same thing!!
