GX500 build
Flyinhillbilly
The great cornholio
North West Arkansas
at this point the motor has as many ccs as some twins do. also since you two are the ones to ask if i where to do a high torque vtwin mower engine would two smaller carbs that are linked together make more torque and power with a long intake? or the stock carb with no governor?
Long intake runners are conducive to building torque, so I’ve always been a fan. I’d run a slide carb with a common plenum and long runners if I were the one doing it.
Flyinhillbilly
The great cornholio
North West Arkansas
Well, how’d ya do? Are you still racing with your girlfriends boys?
They quit and just play basketball.
I came from tailback and won the heat, and won the feature by half a track.
The track was wet and heavy, and I could put the power down. I tend to struggle on slick tracks because I tend to spin the tires a lot. When it’s wet and tacky, that kart is a force to be reckoned with.
