GX340 Throttle
pinoyclass
I currently just purchased a frame and installed a seperate engine honda gx340 11hp. I have it set up with a comet 40 series torque converter on a jackshaft with 10T sprocket going to a 60T sprocket. I test drove it this weekend and felt pretty good compared to a 6.5hp honda clone with a similar 30 series setup.
Anyway my question is I hooked up the throttle cable to the lever but after riding it around I felt the engine had more potention. I put the rear end on blocks and reved the engine by hand with the lever. I then reved the engine by the linkage directly connected to the carb and wow what a difference. Is this opening it up to the full 3600rpm or am I essentially bypassing the governer by reving the linkage connected to the carb?
Karl
Blazkowiez
Kart Aficionado
Houston, Texas
Hooking up the throttle should be very similar to doing so to a GX200 of which there are several pages of members doing so. Obviously as you can see the level they call the throttle control goes to the governor rod before it travels to the butterfly on the carb. If you were to operate the butterfly directly you would not be engaging the governor.
If you expect the engine to last a good period of time I personally suggest you use the governor and use gearing to achieve greater speed, the engine should be significantly strong given its size.
pinoyclass
Thanks for the reply. I hope I didn't do any damage. It's very tempting though bypassing the governor!
What about load- if the kart is geared too high for its weight/tire size, you will experience that, too. It will go like mad on the stands but seem like the throttle's not all the way open when loaded. This is an illusion- in reality, the throttle IS wide open, and the governor is NOT limiting you. But you're not turning 3600RPM because you don't have enough power for the gear ratio you have.
So- what gear ratio are you running, how big are your tires, how heavy is your kart?
r_chez_08
Should be in the shop...
Cornwall, UK
if you want you can remove the governor... the flywheel will be fine. dont get new valvesprings though unless you want a new billet rod.
rob
pinoyclass
After I put the kart on blocks I tied a string to the buttery fly linkage and drove it around by pulling the string and it was a lot faster and had better pick up from a stop.
As far as gearing I don't know how to calculate it but I have a Comet 40 series Torque Converter, 10T to 60T with 22x11 rears. I'm not sure how heavy the kart is I'd make a guess around 350-400 lbs? It's a single seat Coyote Sport and has a serial # tag that says USA Industries on it but can't find it online. I'll try to post a picture later maybe someone can identify it.
r_chez_08
Cornwall, UK
gear ratio should be ok.. its a gx340 ;) is there any way of bending the linkage to allow you full sweep of the butterfly?
rob
It's one thing to have the governor limit top speed, but if the "string" trick got you better acceleration, then I'm inclined to believe there's something not right with your throttle linkage, that's not allowing full throttle.
pinoyclass
I'll try to bend it over the weekend but is that essentially still bypassing the governor?
