GX270 help - possibly valves
Carlman
Ok i may change out the sprocket for a 35 tooth one which will give me 95km/h at 5k rpm.
I assume standard size rings and original piston will be fine with a hone?
solomon
ca
yea, as longas the piston isn't scored you can reuse it, and it is recommended that you purchase new rings (std. size) and install them. But if your rings look good, i would soak the piston w/ rings on it in oil for a day and then remove it and degrease it. Then just put a little oil around each ring when you install the piston and rings back into the motor. MAKE SURE YOU LUBRICATE THE CYLINDER WALLS BEFORE YOU REINSTALL THE PISTON
anderkart
Surprise Arizona USA
a 12t clutch
26cm diameter rear tires
5k rpm
I ran your 35 tooth #'s and came up with 87KPH or 52mph. At first I thought your 12/35 ratio sounded kinda wacky but 52mph from a 9hp. actually engine sounds fairly do-able to me. You wouldn't have super good acceleration and you'd be stressing your clutch more cause it would be slipping longer before it would finally lock in, but I think this would probably work out ok as long as you and your kart are not too heavy and you'd be mostly riding on flat/level hard surfaces. (prolly wouldn't climb hills or accelerate in loose dirt/sand very well)
I think it kinda also comes down to how good of a clutch you have. What brand is it, and whats the max HP. its rated for ?
Carlman
Thanks for the reply anderkart.
Yea change of plans though, not running this engine as ive got ahold of a yz80 engine around 20hp. The gx270 is going on a mini bike that will be geared to do about 60kph.
I have a comet heavy duty rated for 15hp, it has needle bearings.
brendonv
Australia, Perth
Just for future reference solomon and anyone else. We are Australians, we dont have seafoam. We do have a similar product (injector & carbon cleaner) at the auto store but yer. Ive personally never used the stuff. Dont really see the point (its like 25 bucks!). A good flogging will sure clean it out. If it doesnt a little alcohol sprayed into the air cleaner should do the trick hehe. (the last one was a joke btw)
solomon
ca
Where did i mention anything about seafoam? I have never even used the stuff
