GX200 idle adjustment screw
loneagle
I need to richen the idle a little. There's a limiter on this screw, now is this just a cap that can be removed or will I have to do a little grinding with my dremel?
Kenny_McCormic
Kartless....
Michigan Troll
The little EPA plastic cap? cut the tab off if necessary but first pull it off to see if the spline shaft underneath is slotted for a screwdriver.
oscaryu1
You can turn it clockwise with pliers. Replacement carbs from gxparts n' such don't have a cap.
loneagle
Mine is a Honda carb. The cap is made of aluminum and I used my dremel to grind the stops off. I set the screw a 2 turns out but the engine still pops on decel. The carb has a #90 main jet and a 140 emulsion tube. I'll keep playing with it.
