GX200 electrixlc start wont work
TonyMontana214
Dallas
the battery is working, the solenoid is getting juice but nothing happens. not even a click when i turn the key. the circuit protecter is pressed in and none of the fuses seem to be burned out. the red wire is on the solenoid where it needs to be and the ground is, well, grounded. oil sensor has been removed as well as the charging system. WHAT IS WRONG!? its driving me nuts
Sent from my SM-G955U using Tapatalk
TonyMontana214
Dallas
how do you do that? i was wanted to try that but dont know how
---------- Post added at 11:36 AM ---------- Previous post was at 10:49 AM ----------
everythibg seems straight forward.
TonyMontana214
Dallas
alright so i made a bridge here and the starter turned on. if i turn the swtich it doesnt do anything
Probably a bad switch. If jumping the starter on the solenoid with that screwdriver got it to start, probably a bad switch.
TonyMontana214
Dallas
thats what i figured. it was working fine up until now. i removed the pil sensor and the charging coil. would that have messed with it? i have these two cables just chilling here
