Wait, no, drop the conrod; if you're upgrading, you need a billet conrod, that's an OEM, no better than what you have now; a billet rod will cost you a bit more than that...
Cover your mouth with your hand, now take a deep breath in & out; hard work isn't it? That's what you're engine is doing...
Now take a deep breath in then cover your mouth & breathe out; that's what your engine is doing with a hi flow air filter & stock muffler...
"The better an engine can breathe, the better it will perform"
As for the jet & e tube, you need to let the engine tell you what it needs once it can breathe correctly, otherwise, you'll only be force feeding it which will hinder performance
"More fuel is not always the answer..."
