GX160- what's this all about?
r_chez_08
Should be in the shop...
Cornwall, UK
Hi,
Today I have been messing with my mini bike. It had a gx160, wiener pipe without muffler (small straight pipe, 3/4" O/D used by clone BS karters), gx200 carb and 20 thou copper head gasket to replace the 45 thou layered gasket and bump up the compression.
The motor was not idling right. It was surging around a bit, and I couldnt remember when it started doing it (what part change).
I assumed this was to do with a damaged governor spring, so today I spend half a day removing the governor (forgot how much of a PITA the gear is, ended up removing the flywheel and punching out the gear axle). I also made a neat throttle setup based on a design by bluethunder.
Whilst I was inside the motor I swapped out the cam for a stock gx200 clone one. The gx200 design has more duration than the gx160 design.
I also replaced a cracked carb insulator and checked gaskets as I thought this may have been an issue.
Put the motor back together, and the motor would harldy run off choke, it certantly wouldn't idle off choke, and idled high and lumpy on choke. I decided to re install the gx160 carby after fiddling with the low speed jet on the gx200 one.
Same issue. No better. So I thought- Maybe the header? Surely not...
Swapped out the wiener pipe for the stock muffler. The motor idled pretty good now. Didn't seem quite as responsive on the throttle but that may have been deceptive due to the harsh rapp of the straight pipe.
So why would the straight pipe cause the symptoms of a lumpy idle and hardly running off choke?
Oh and on a side note, there was gas in the oil as well (I think. It was thin and smelt of gas). What would cause this?
I think I will reinstall the gx200 carb, because this was not the issue and the throttle bore is .040 larger.
Thanks
Rob
anderkart
Surprise Arizona USA
Did you check if your header was somehow plugged up?
I had an old truck with a plugged up tailpipe. It was double-wall tubing and when they bent it, the inner wall just collapsed and kinked inside, plugging it up.
________________
If there's lots of gas in your oil, the needle & seat valve in one of your carbs must have stuck open and flooded when the engine was running, or more likely over night when it was shut off.
klicky96
Sandusky, Ohio
The best way to increase performance with the exhaust is the get the exhaust out of the cylinder as quickly as possible. With the straight pipe, there may have been a restriction, keeping a lot of the exhaust from leaving the chamber. This is ssometimes caused when the exhaust is not wide enough to release the exhaust fumes quick enough, not releasing all of it from the chamber through the valves, and when the valves close, there sometimes is a huge buildup of fumes. This creates a block from the spark from the coil to ignite the gas fumes. This can create a miss-fire, or an unsteady idle.
r_chez_08
Cornwall, UK
Thanks for te replies. I will check for anything that may have been restricting the flow in the pipe. It worked fine on my gx200 clone though, just figured I would make a larger straight pipe for that because I plan on going over 6k if possible, and these little pipes make that hard.
The I/D of the pipe is close to that of the original muffler, and it is a very simple pipe with one curve. Here is a pic
Edit: just tried the clone carb with the stock muffler. The issue comes back.
So it seems either the change in carb (slightly larger) or the change in exhaust does it.
I am going to try the clone gx200 carb with the Honda gx160 carb jet/e tube because they are different.
klicky96
Sandusky, Ohio
Yeah, I wouldn't see that exhaust causing the problem to tell you the truth. It may be your carb. That exhaust should work just fine.
Nodroz
Belgium (Europe)
:iagree:
He said he has this problem on both his carbs. I would be very unlikely they both are clogged up or something wrong.
Altough, I don't know the reason why the engine is doing this... weird.
Same here, I'm baffled (excuse the pun) but, I;m also confused; how many carbys have you tried? :confused:
I'd just find a combo that works & call it a day :surrender:
r_chez_08
Cornwall, UK
Ok-
Gx200 clone carb, straight pipe= worst
Gx200 clone carb, stock muffler = bad
Gx160 carb, straight pipe = bad
Gx160 carb, stock muffler = OK.
I am going to try the gx200 carb and gx160 jets and e tube.
Bluethunder3320
does it have good compression? did you adjust the valves?
a few ways that gas gets in oil, head gasket leak. worn cylinder, piston or rings (blow-by). needle and seat dirty or not adjusted right.
ive run a gx200 with no exhaust at all, and it idled fine
r_chez_08
Cornwall, UK
The bore looked good when I took off the head. Installed a the diy .020 copper head gasket (which was annealed before installation).
I will check the new oil tomorrow. I genuinely do not have time to strip down this motor. If it is a ring issue, I will just run it till is cops out, then replace the rings and possibly piston if they have worn that bad, and hope the rod hasn't been too badly lubricated. Not the correct attitude I know, but this motor was £50.
Hopefully it is a needle problem. The motor feels like it has plenty of compression.
Adjust the valves- what lash?
Yeah. The base circle on the clone cam was larger so the valves were stuck open. I loosened the rocker stud until there was a slight bit of play, then tightened until lash was almost 0. Couldn't be arsed to find a feeler gauge.
