r_chez_08
Should be in the shop...
Hi,
Today I have been messing with my mini bike. It had a gx160, wiener pipe without muffler (small straight pipe, 3/4" O/D used by clone BS karters), gx200 carb and 20 thou copper head gasket to replace the 45 thou layered gasket and bump up the compression.
The motor was not idling right. It was surging around a bit, and I couldnt remember when it started doing it (what part change).
I assumed this was to do with a damaged governor spring, so today I spend half a day removing the governor (forgot how much of a PITA the gear is, ended up removing the flywheel and punching out the gear axle). I also made a neat throttle setup based on a design by bluethunder.
Whilst I was inside the motor I swapped out the cam for a stock gx200 clone one. The gx200 design has more duration than the gx160 design.
I also replaced a cracked carb insulator and checked gaskets as I thought this may have been an issue.
Put the motor back together, and the motor would harldy run off choke, it certantly wouldn't idle off choke, and idled high and lumpy on choke. I decided to re install the gx160 carby after fiddling with the low speed jet on the gx200 one.
Same issue. No better. So I thought- Maybe the header? Surely not...
Swapped out the wiener pipe for the stock muffler. The motor idled pretty good now. Didn't seem quite as responsive on the throttle but that may have been deceptive due to the harsh rapp of the straight pipe.
So why would the straight pipe cause the symptoms of a lumpy idle and hardly running off choke?
Oh and on a side note, there was gas in the oil as well (I think. It was thin and smelt of gas). What would cause this?
I think I will reinstall the gx200 carb, because this was not the issue and the throttle bore is .040 larger.
Thanks
Rob
Thanks
Rob
