I've fooled around with my gx160 quite a bit and have incorporated many mild eninge mods. after perform alll the mods my engine performed beautifully. However recently, i pulled out the low oil level sensor and introduced a flat top piston and gx200 gasket to the mix. Now the engine won't start. Be for i was runnning the stock head and gx160 head gasket. it could be possible im running to much compression for my cam which has a max of 10 to 1. However i was wondering if i did something to the circuitry by taking out the low oil sensor? thanxs
