gtc torque converter problems
HELLSUNICORN
I purchased a GTC 30 series with a 1 inch driver a couple of years ago. I have finally gotten around to installing it. I am installing it on a brand new 8 hp Harbor freight engine. The problem I have is that once the engine is started the belt does not slip at all and the cart wants to go forward. If I have the cart on the hoist the torque convertor works correctly with the exception that it will not allow the belt to slip at idle.
I have adjusted the idle down as far as it will go. It is not an idle issue. It seems to me like the belt is to short. The belt is the correct number they list on the website and it is the belt that came in the kit. The belt is very tight once it is installed. I have the belt facing the correct way and the pulleys are aligned. I also have the shaft of the engine centered in the hole of the back plate..
At this point I'm stumped. Either the backplate is machined in correctly, the belt has shrunk or it was manufactured wrong.
Any ideas would be great. I would like to have this running this weekend for my daughters birthday. Thanks in advance..
KartFab
Dallas, TX
Make sure your Jackshaft and engine shaft are exactly parallel to one another. The belt should not be tight at all.
1) Check the belt markings, or measure it's outer circumference.
2) measure the distance from the center of the Jackshaft to the center of the engine shaft.
3) reference the center to center distance on this belt chart.
http://www.gokartsupply.com/tcbelts.htm
HELLSUNICORN
Thats my problem. This is the belt that it is supposed to use. It is listed as this belt on the GTC website and it came with the kit. The back plate is a solid piece of aluminum. I cannot adjust the distance between the 2 pulleys.
Is it possible the belt has shrunk from sitting a few years?
KartFab
Dallas, TX
Pull out a tape measure, and do steps 1-3.... I know that may sound repetitive to you but it never hurts to actually just follow the steps just to confirm that is not the problem. Your belt should have some play in it and it should not be tight against the drive units shaft. When you say "the belt is very tight once it is installed" that means it's a center to center distance problem if you have it all lined up correctly. If you can't change center to center, measure it and buy a belt that matches your center to center.
Also your driven unit could be 6" or 7", so make sure you get the right center to center and driven unit to find the right belt.
These belts do not shrink or stretch that I know of. Not like an automotive belt that stretches a little at first.
Also, if you could post a few pictures that would help, but based on your description, your problem screams "my belt is too small".
HELLSUNICORN
This is a 30 series GTC. The driven pulley measures at 6 inches outside diameter. The center to center on the shafts is 6 3/4 The belt number is 203589 According to the cart this is the belt.
It is tight even without the pulley on the engine shaft.
HELLSUNICORN
Here is a picture with the driver removed. It is very tight even over the shaft.
KartFab
Dallas, TX
Ok so the chart says the correct belt is 5959.
If your center to center is even a little bigger than the specified range for the belt, then you are out of luck. If the center to center is a little smaller than the specified range, then you should be fine.
Hope that helps! Like I said before, the belts don't stretch. If it is possible, maybe you could unscrew the bolts holding the backplate on and then try shortening the center to center, but from the sound of it your out of luck.... Why not drill them out a little or try another torque converter angle/position?
I have a GTC torque converter on my mini bike and it worked out just fine. Looks like you weren't so lucky. Also be careful with the Jackshaft snap ring. My driven unit flew off when riding around because I over tightened the Jackshaft nut.
HELLSUNICORN
The chart is saying 203589a not 5959. 203589a is what I have. Am I reading the chart wrong?
I am 6 3/4 distance on the shafts with a 6 inch driven.
I agree my problem is the belt is to tight. I just don't know why.
I think I am going to try and clock the backplate to see if it helps. The most I can get out of it is about 1/4 inch.
Thanks for all the help. Im just annoyed with this thing at the moment.
I would also say 203589a. Give GTC a call and ask them about the belt. What does your belt say? Does it say 203589A? GTC might have provided you with the incorrect belt, and you are just assuming that they wouldn't do that
The belt should not be tight at all, on the contrary, it should actually look quite loose
I have to agree with gran pann here...
if you don't find a perfect match, it's better to have the belt a tad too long than too short.
But strange enough, that the center to center on a mass produced backplatel is not what it should be.
So assuming there's no error in measuring the ctc and it's indeed 6.75
you should get a 5959 it's more likely to slip at the lowest engagement speed;
but it'll at least idle without engaging ;)
Fast Eddie
Out in the garage
Make sure you have the correct width belt. If your belt is too wide it will lock up as well. Also make sure the shaft bushing between the two halves of your driven clutch is in place. If that is missing that will pinch your belt.
HELLSUNICORN
Just to update this. I ended up clocking the backplate. That did not help with my problem. I ended up buying a new belt with the same part number. Once I put the new belt on on it was obvious what my problem was. The old belt had shrank or was manufactured incorrectly. It was shorter than my new belt. The cart is up and running again and is a lot more fun with the new motor. The t/c has no problem handling the new more powerful engine and will even haul 2 adults with no problem.
