modelengineer
Lord of the noise
That aren't supposed to make power down low, my CBR 600F2 starts pulling hard about 6000
My point still stands. Low down torque is what you want in a buggy.
You don't need a gauge cluster, but you might want to see if you can pick one up on Ebay anyway, they generally aren't that much money. One thing I would strongly recommend is to get a shop manual for that motor/bike, it will help immensely with wiring questions. I'd check Ebay for that, and the radiator too, I got the one for my kart from a Kawasaki Mohave off Ebay (it was the right size and shape), and it's was $39, shipped, with coolant reservoir and cooling fan included. AFAIK, there are not any sensors other than the cooling fan switch (in the radiator), but you can do that with a toggle switch just as well if you wanted. You said it's a 99 right? And carbed?![]()
if its Carbed why would you need a TPS??
If the stock bike system had a fuel pump, you probably will need one, the mower pump may work. The CDI box and coils are usually mounted on the frame, so make sure you get them and the wiring harness with the motor, the CDI units aren't cheap if you have to buy them.yeah i already managed to find the shop manual online. it is a 99 or 2000 and it is carbed. I take it that the cdi box and everything to do with ignition timing should already be mounted on the motor?
so all i will need to get other than the motor he is selling is the radiator/fan/reservoir. i have a fuel pump from a lawn mower, can i use that? if not i can just gravity feed it? the stock system did indeed use a fuel pump.
also, i am going to NEED a throttle position sensor if its not on there already correct?
thanks again guys
The one I have on my kart is just like the DF52 models, but it's only a single outlet, probably because it's actually an OEM pump off a jetski. It takes the same kits as those though.![]()
I just sold 2 of those same 1 outlet pumps on here, they came off a 3 cylinder sled that used one PER CARB (triple carb), wish i coulda seen that sled running, 750cc and 140hp stock.
Are you sure this bike has a fuel pump stock and not just a diaphragm petcock? i cant see it using so much fuel that gravity couldn't keep up with it.
Does indeed appear to have a fuel pump AND a diaphragm petcock.
Gravity should work, might need larger needles and seats in the carb. Even if it wont work gravity feed, those mikuni fuel pumps are cheap.
