Uhh, NO! To remove it, you must open the case. Remove the arm from the outside. Cut the top off of that rod. Push it INTO the block to remove. Then remove ALL the remaining govenor peices inside,like the plastic gear and stuff. MAKE SURE THE 2 DOTS FROM THE CRANK AND CAM LINE UP BEFORE. YOU PUT IT BACK TOGETHER OR IT WONT START.....
