Governor 'bypass'
Everett45
Idaho
My go kart has an 8 HP B&S Flathead. My throttle setup is as follows: cable from the pedal attached to the governor arm, which operates the linkage on the carb. The governor arm has a RETURN spring on it, to allow the throttle to close automatically. I've ran this go kart several times (not a lot by any means), one time on a gravel stretch of road. I actually never went full throttle. My question is since the internal governor is effectively bypassed, but is still installed, should I leave it and just not floor it all the time/for 10 seconds straight? Or should I remove it so it doesn't come apart from higher RPM's? I've heard that with removal/bypass you can be mostly safe from over-revving because of valve float. Not sure if that is the case. What can I expect from keeping it disabled either way in terms of damage?
So is it disabled or not?
Please post up a pics of how you have it set up so we can see.
It seems like there are a few methods that work for bypassing. But with out removing the internal parts there is no guarantee.
Everett45
Idaho
Here's a picture and a little diagram to better demonstrate:
I'm not currently sure as to the correct routing of the throttle, but you have the cable through a mount in a almost 90* fashion... Without a cable jacket... That will cause problems later shortly, if not already part of the problem...
Additionally, that's quite the older model of Briggs you have, almost looks like my big #14 I have, same style of carb, be a real shame if thing went awry and screwed that motor from messing with the gov.....
Everett45
Idaho
you have the cable through a mount in a almost 90* fashion... Without a cable jacket... That will cause problems later shortly, if not already part of the problem....
It's hard to tell the angle in the picture, but it isn't as sharp as it looks. It's on the frame at a 45 degree angle, then goes up a bit. It is actually quite smooth and doesn't cause any problems.
As for the engine, yes it'd be a shame if it blew :/ I don't plan on thrashing it, but nor do I plan on only putting around. I take care of her regardless, always letting it warm up and such.
