My go kart has an 8 HP B&S Flathead. My throttle setup is as follows: cable from the pedal attached to the governor arm, which operates the linkage on the carb. The governor arm has a RETURN spring on it, to allow the throttle to close automatically. I've ran this go kart several times (not a lot by any means), one time on a gravel stretch of road. I actually never went full throttle. My question is since the internal governor is effectively bypassed, but is still installed, should I leave it and just not floor it all the time/for 10 seconds straight? Or should I remove it so it doesn't come apart from higher RPM's? I've heard that with removal/bypass you can be mostly safe from over-revving because of valve float. Not sure if that is the case. What can I expect from keeping it disabled either way in terms of damage?
