Governor ADJUSTMENT (delete?)
Sparkwizard
Richlands ,NC USA
By moving that cotter pin, you are giving that spring more room to move. Is that spring under tension when the pedal is at rest? Moving that pin and installing a longer spring shouls do what you want.
It looks like you have a solid wire throttle cable with Z bends on the end. This is only suitable for static engines (like garden tillers, snowblowers, etc) with a set-and-forget style throttle, the type that stays in one position at all times by friction.
You need a stranded cable or it’s just not going to work right.
Squiddy202
Manco Dingus
Eastern Pennsylvania
I knew that at first but with a pinch bolt it works great.
When you gonna add a FLOOR to your kart? The possibility exists that you may run over your own feet.
SAFETY THIRD! 🚑 🤕
Sparkwizard
Richlands ,NC USA
Those solid wire cables are NOT made for recreational vehicles. They have a wire wrapped sheath that is designed to HOLD the cable from moving freely for tillers, mowers and other engines that need to maintain constant throttle for a long time. Not good for karts. Stop telling us it'll be fine when we tell you it is just wrong, OK?
Squiddy202
Manco Dingus
Sorry, I will change that, but it is behind getting a good return spring, and brakes that work decently.
Lets get the basics.
Un attach the cable from the carb.
When you push the pedal all the way down, what stops it. Does the pedal itself hit a stop? or does the spring bind and the cotter pin bottoms out.
Now look at the cable sticking out. Make some marks if needed. Measure how much travel you have.
Compare that with how much travel the linkage has.
It sounds like your linkage has greater travel than the cable.
Move the attachment point closer to the pivot of the linkage.
Some times (caution) you can have some one hold the pedal all the way down and set the cable where the carb is all the way open. Then see if theres is enough travel in the system to reset the carb at idle.
If it doesn't go to complete closed then do not leave it like this.
The point is to have just a tad of slack at no throttle and the pedal should hit the stop just a tad before WOT. You dont want to rely on the carb to stop your foot.
When you quit monkeying around with the wrong parts, and get the right ones it will be much easier.
Also it takes good brakes to go fast!
Your getting there.
You described a pinch fit, but the throttle cable should be secured on the throttle mechanism-lever with a wire swivel stop, just to be sure. This will permit a full(er) range of motion but you still need a stranded cable. The solid wire you are using is definitely part of your throttle woes.
Having double return springs is not uncommon. Some karts have a spring right at the pedal and another spring at the engine/carburetor. This is to ensure that the throttle immediately snaps back to idle when you let off.
Throttle cable lubrication is a thing as well, a weekly maintenance thing for motorcycles and such as there’s just so much moisture in the air and people ride in the rain or through wet environments (crossing creeks and streams) and soak their cables on a routine basis. Water wicks into every orifice and crevice and can even defy gravity via capillary action….
Squiddy202
Manco Dingus
I have a swivel, I described poorly. It is like predators in that respect. I am looking at getting a good cable. For now I want to see what I can do now. I might try to use old bike cables like someone (I think spark) mentioned.
Sparkwizard
Richlands ,NC USA
Remove that spring, take it to Lowe's, Ace Hardware, Home Depot or your favorite big hardware store. Find their display of wire goods. Look for a spring that is longer but has thinner coils. That will give you more pedal and it won't bottom out on the spring so soon. A thinner spring can be compressed into a smaller space. Look for a kart or bicycle cable that is multistrand. It will have a teflon or nylon sleeve inside to reduce friction, so a heavy spring won't be as critical, anyway.
Squiddy202
Manco Dingus
So there is another issue other than the spring. Even if I use a bike cable or something this issue will still be here. I am going to change it soon, but there is nothing that anchors the cable to the bottom cable bracket. Whenever I try to mess with the cable to check travel the sheath pulls straight out. Should anything be holding it in or will it work well when everything is tied down at the linkage?IMG_1983.jpeg
Sparkwizard
Richlands ,NC USA
You need to anchor that cable sheath. Look at bike brake levers for the hollow bolt that the sheath seats in ansd the cable passes through. Maybe your sister's bike has one you can look at.
Squiddy202
Manco Dingus
Those the cable sheath can pull straight out of. This is doing the same thing. The black part stays on the cart, not the sheath. The sheath pulls from the black part. I think the nuts you mention are the barrel adjusters you are talking about are the standard ones that do the same thing. I believe I phrased the question poorly.
Is this the type of thing you meant?:
I am wondering if after I tighten everything up if there will be a force pressing the sheath into that hole. Otherwise it would need some anchoring that is not provided on bikes or the current solution.
Sparkwizard
Richlands ,NC USA
Here's my suggestion...AGAIN... get a cable for a bicycle and use bicycle hardware...compatible parts do not have issues. Motorcycle cables and motorcycle hardware are more expensine and harder to find, but are much stronger.
For the field expedient method, try to find a small washer or drill a small hole in a piece of metal and thread your solid cable through the washer on the other side of that plastic piece.
Squiddy202
Manco Dingus
Update:
Firstly, I am going to not mount the spring with a zip tie forever. Same goes for the cotter pin. That was to test. My dad had an expansions string in the basement. The old one was cut, and not returning the pedal all the way so I wasn’t setting the cable to use all the travel.IMG_2004.jpeg
Notice the throttle cable snaking through? I stole one of a crappy kids razor e-scooter I got scammed into buying on yard sale day. “It only needs a charge.”
I wasn’t sure if the olds spring or the carb mech was stopping the pedal so I put the limit screw in by a tiny bit past WOT like WTR said. I also have two questions. One, the pedal hits the steering bar by a little, you can see the worn paint. Is that a big issue? I can steer fine still.
Second, this was like this since I got the kart from marketplace. I feel like these holes on the crankcase should have bolts, how much of an issue is their absence? I don’t seem to notice oil leakage.
P.S: Downhill before I had to hit the brakes. I only had like half a block of alley.IMG_2001.png
