got oil in it...then my cousin decided it would be a good idea to sit in it, loosening the kill switch. the ground wire is no longer connected. is that enough to not let it start? because now its not starting, and I have no idea why.
You may have too much oil in it. If you overfill with oil, the breather will suck oil into the carb & cause it to blow lots of smoke
where do I spray? right where the choke control is? (underneath of the air filter)
Have the wheels off the ground too.
We're doing a great job of filling in each others blanks
I knew I forgot something...
Sorry, for some reason I didn't see the bottom end of that post about the filter. I have one of these http://compare.ebay.com/like/110699960116?var=lv<yp=AllFixedPriceItemTypes&var=sbar
Thanks.
