hey... new here and i was thinking of building an electric go kart just to mess around with, could you direct me to a good place to start motor wise and motor controls. also im not an aspiring mechanic or anything so keep it simple and any tip or hints would be well appreciated.
thanks
DABRUNO
Hey dabruno,
Motor, Are you going new or used?
Plenty of new to be found with a google search.
Used, plenty of golf cart motors or a low voltage
industial dc motors.
Batteries, do plan on using lead acid or you going high tech?
Decide on a system voltage, (may depend on the motor you get)
If you go above 48Volts the controllers get more expensive.
Controller manufactuers, Alltrax, Curtis, and more.
You will need either a potbox or hall device connected to
your throttle to control the motor speed controller.
Get a solenoid to energize the controller system and
an emergency button to shutdown if the controller shorts.
You probably want amp and volt meters on the cart.
Even if you are a good scrounger expect to spend more than
$700.00.
Here's a video of the kart my son and I put together about
a year ago. It's in rebuild now, (progressing slowly :-( )
http://www.youtube.com/watch?v=5MKjbXltAew
I'll look around for the schematic I used and post it.
Mike
