Going Faster With a 2:1 Reducton
qtband
St. Louis, MO
I've been working on getting this commercial kart, "Big Blue", up and moving. I have the engine running and I rebuilt the MCP hydraulic brake system. The 9hp Honda has a wet clutch with a 2:1 gear reduction. I gave it a test run and it handles great, but speed is lacking. I'm sure it's built this way because of its original intended purpose.
I'm thinking that I will replace the belt drive with a chain drive and change the ratio to get more speed. If I keep the wet clutch and gear reduction, my rpm at the output shaft will be around 1800 rpm. If I use a 16T on the output, 45T on the axle, my speed will be around 30mph.
My question is... with a gear reduction and this ratio, will the kart be able to get moving from a stop?
Flyinhillbilly
The great cornholio
North West Arkansas
I think it would be fine at 3:1. You just have to figure the final drive ratio, so multiply your axle ratio by two and you'll have you final drive ratio.
qtband
St. Louis, MO
OK, I get it. If my ratio from the wet clutch to the axle is 3:1, then my final drive is 6:1. That should be OK.
Now, can I use a 40 chain or do I need to go to 50?
thebroketeenager
Bakersfield California
My kart used to have one of those reduction drive boxes. I have to warn you, those clutches don't hook very well when they get hot. From a dead stop it will accelerate but not too well. It should be said though that the clutches i used were pretty worn, likely yours will too b/c it was a commercial kart. Short answer: yeah you'll probably be fine.
But if you ever want to upgrade to a new clutch you're done for. The PTO shafts on those motors are a different size and length, they wont fit a normal 3/4" clutch. I had to get a new motor to fit the TAV I bought for my old honda.
