Go karts
Richrrjr
I have a cross fire frame with 16 hp duro max on it with a torque converter with a 10 tooth sprocket on the front and a 32 on the back does not seem to want to go anywhere I just burns up the belt
You're geared way too high. You need to be at 6:1 as a start and maybe go up. What's your current tire size?
anickode
S.E. Michigan
You should have somewhere between 54-72 teeth on the axle depending on tire size. With 15" tires you could probably get away with 54t, and the bigger the tires are, the more teeth you'll need.
I'm guessing this cart originally had a GY6 with some internal gearing, and the first stage of reduction (integral to the engine) was eliminated when the 16hp and torque converter was installed.
BeaterofAincrad
2018 Build-Off Contestant
Vermont
So you need to be at 72 minimum. Possibly 80-84 if you plan on lots of hills, sand, mud (real off-loading)
Should I stick with I think it’s a 60? I’d like to try a little lower if I won’t be burning through belts, size is 18/9.5-8 and it’s a 195cc/6.5hp
