I have a Streaker go kart and you can't crank it without pressing the throttle, and to make it idle, i have it low as i can to keep it going, but it tries to take off.
Someone wants to buy this today, so i need advice on how to fix this!!!
It's a tecumseh 6.0 HP motor and i've tried the idle screw so many times. It should still crank without pressing throttle. It's never done this before.
i know this is a little late but try cleaning out the bolt that holds the bowl on and make sure where the needle goes that its not blocked and losing gas flow
