Go-Kart won't crank without pressing the throttle...
Axton
Hi guys,
I have a Streaker go kart and you can't crank it without pressing the throttle, and to make it idle, i have it low as i can to keep it going, but it tries to take off.
Someone wants to buy this today, so i need advice on how to fix this!!!
Axton
It's a tecumseh 6.0 HP motor and i've tried the idle screw so many times. It should still crank without pressing throttle. It's never done this before.
A little more info is required. How long ago was it last run? Was everything "perfect" last time? What happened after that? Is the governor intact?
Sounds like the carb may still need some de-gunking.
Axton
It ran fine till about 3 weeks ago. I will clean the carb again.
It was perfect, it crank right, it went fast, it was just perfect.
Monkeys1990
texas
i know this is a little late but try cleaning out the bolt that holds the bowl on and make sure where the needle goes that its not blocked and losing gas flow
