Go-Kart Takes Off on Startup
Brayson
Hello
I have been looking around for awhile to see if someone has answered my question already but I have not found anything yet so I decided to make a post.
My Go-kart:
It is a manco 606 with a brand new HF predator 212 engine (Replaced an old Subaru Robin EX17 6.5 HP that needed a lot of work and I didn't have the resources for it.) The torque converter Drive pulley is a Comet 219552 that was on it when I bought the kart (It's about 8 years old) and it has a brand new 203589/5959 belt on it.
My Problem:
Right when I start my engine my torque converter drive pulley engages about half-way and my kart takes off.
What I need answered:
Is my drive pulley malfunctioning
Is my idle speed to high
What do I need to do?
Other:
I made this topic because all the ones i find are on centrifugal clutches
Please don't tell me to loosen or tighten my idle screw, I've taken it out and it still happens
IF YOU NEED PICTURES TELL ME!
Thanks
Bbqjoe
Banned
Location, Location
Hello
My Go-kart:
My Problem:
Other:
Thanks
Thank you. We don't need pictures. Most guys are pretty good at guessing what's wrong without them. Pictures only confuse them, and make them cry.
ond
Russellville, Ky.
On this new Predator engine, are you using the original lever system on top of the engine to hook your throttle cable to ? If so you need to loosing up the center pivot nut on the Predator engine throttle lever system.. .probably two or three rounds so it moves back and forth really easy. Let me see if I can find a pic.
ond
Russellville, Ky.
Good Idea ! Do you think the engine swap some how made the belt tighter ? Does it sound like the engine is idling to high ? Throttle cable loose and not to tight ?
---------- Post added at 06:30 PM ---------- Previous post was at 06:28 PM ----------
Pics might help ! Video of it running would be great .
Brayson
The new belt came in today and the 212 is the only engine it has ran on, the throttle cable is fine nothing is wrong with it, and t6he engine sounds fine when idle, the drive pulley on the torque converter just engages about half way right when I turn it on
MTNSleder
😈 Snake ƘƖԼԼЄ&
USA/CANADA
Clean you Torque Coverter I'd start there... 8 year's old there's definitely some rust and dirt built up.
Also your garter springs could be wore out too...
in which case your idle is too high (well above 1200 rpm.. closer to 1800 really)
or which is also a possibility.. your garter springs are worn out.
In which case you need to unhook them from the weights and check their length (be exact!)..
report back here and we'll tell you if they need replacement or not.
Brayson
alright ill get back to you in a little bit, I ordered a new pulley on Wednesday thinking it might be the answer to my problem, and on terms of rust I have sanded it down and have made it all smooth.
ond
Russellville, Ky.
Just grasping at straws here ...did you get a number off the old belt to order the new one ? What diameter is the rear pulley 6'' or 7'' ?
MTNSleder
😈 Snake ƘƖԼԼЄ&
USA/CANADA
What did you need us for?
Sound's like you've gotten it figured out...
Brayson
well if its not the pulley I need to figure out how to lower my idle speed, and if its the screw on the carb thats supposed to do it, it doesnt work
---------- Post added at 06:52 PM ---------- Previous post was at 06:50 PM ----------
both springs are at 8 inches
---------- Post added at 06:56 PM ---------- Previous post was at 06:52 PM ----------
6" and yes numbers off the old belt
MTNSleder
😈 Snake ƘƖԼԼЄ&
USA/CANADA
Springs!!! there little long...
---------- Post added at 06:02PM ---------- Previous post was at 05:59PM ----------
Edit: There just over 8 inches right? They should be 7 7/8... You measured with a rule not a tape measure right???
ond
Russellville, Ky.
Can you shoot us a pic of the throttle set up ? If you took the Idle set screw all the way out and the throttle flap closed all the way the engine should have died .
Brayson
its not all the way out anymore its about half-way unscrewed
ond
Russellville, Ky.
This is a pic of the nut that needs to be loosened a couple of rounds sometimes three or four rounds, the screw in this pic is the throttle stop....just so we are on the same page. The long screw with the spring on it .
This is the Idle set screw the big black plastic screw on the top.
---------- Post added at 08:02 PM ---------- Previous post was at 07:14 PM ----------
:surrender: HELLO is there anybody in here !?!?!:yawn:
Which is which, OND? Can you go by those ever helpful colored circles?
Unhinged
Loves Cheap Thrills
Oregon
The springs get my vote. :thumbsup: If you wanted to get really techie you could find a shaft tach to check your idle speed with.
