TheWingnut
Hi,
I am building a go kart out of an olg golf-cart frame. Here are my ideas, does everything sound like it will work for the speed of 30-50mph?
The view from the frontwards above view is on the left.
The view from the left where i will be putting my egnine is in the middle.
The right picture is from the back with about where the axel will be placed, accept its on the ground right now.
This is my set up, a bit small, but it can work (100-200lb frame). I want to put my engine on the top half (would like to get a briggs 8hp) of the two haves (left side) in the second picture, with a panel of alluminum lay accroess the open parts of course. Then i would like to get a comet converter
[looking something like this http://www.amazon.com/Series-Magnum-Tor ... 198&sr=8-2]
and hook it up to a jackshaft in the lower space or in-between. That jackshaft will have a small sprocket on it (18-22teeth) and then a bigger one (24-28teeth )attached to the shaft on the axel.
Do you think this will work for how fast i would like to go?
