Go Kart Re-build / Restoration
JTSpeedDemon
2019 Build Off Winner!
Texas
To embed the video, it needs to be the actual URL link from the watch page.
The URL should say watch somewhere in it if it will embed.
Hey, that's a pretty good video mate.
Good production values and usage of a stationary camera(!) no less. You're miles ahead of CarsandCameras (which should be called the Isaac Show, but I digress).
What you could do when you go into 2x speed mode is provide a voice-over narration to tell us what you're doing and skip the music. While you were sanding and using the grinder and a wire wheel(?) (see, I'm guessing because it was so fast), just tell the noobs what grit you're using and why. Tell them why you didn't strip the entire frame to bare metal--I'm sure they expected you to do so.
Anyhoo, not bad at all. :thumbsup:
Kart turned out well too.
bthompson224
DFW
Jbonn
Mech Master
Kaysville UT
Thanks, I've always been on the fence with music. My other I did total choice over but it turned volume was low.
https://youtu.be/KlkVNsgzZBw
---------- Post added at 04:36 PM ---------- Previous post was at 04:34 PM ----------
I thought the production was well done too.
I give you...
:thumbsup::thumbsup:
Thanks. Now I'm on the look out for more frames!
Jbonn
Mech Master
Kaysville UT
As a side note, does anyone know where to get these type of shocks on the yerf dogs. It seems like the ones on ebay and some online stores want way to much for a cheap little shock, or other suggestions of shocks would be great too!
