greasemonkey85
ok i am still working on this. i will be either running my controlled stock flat head or a clone. will be turning either motor between 7000 and 8000 rpm and both making 10 to 15hp. the people at comet said it should handle the rpms and power, just might go through belts more often. anyway...
looking for good down low torque and speed. i will be using #35 chain with the 12 tooth in the front on the tav unit. the back sprocket is up to my imagination. i have every gear from 50 to 84 for the axle from my racing kart. any ideas?
18x10x8 tires and will probably weigh around 400 to 450 lbs.
would like 40 mph maybe 50mph but definately looking for wheely kind of torque too. any help here would be greatly apreciated! thanks dan
